Printer randomly resets mid-print
Burcadus
(@burcadus)
Hi!
Our MK3S stops mid print (regardless of the height) and resets with no error message or else. As if somebody would have pressed the reset button. Here are more infos:
  1. The printer is 4 years old and is used daily
  2. The «resetting»occurs regardless if the print is made by Octoprint or from the SD card
  3. Nothing changed in our setup recently
  4.  I turned Octoprint logging on, and I observed 2-3 of those comments per day : Printer sent 'start' while printing. External reset? Aborting job since printer lost state.
  5.  I found this : https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/mk3-resets-while-printing/#post-70778 about grounding the board to the frame, I didn't try it yet since I wonder why it would suddenly become necessary.
I presume some part is getting old and needs to be replaced. What do you think I should replace first? My bet would be the power supply...
Best regards!
Posted : 31/01/2025 10:05 pm
RE: Printer randomly resets mid-print
Before you start replacing parts it would be worth checking the existing wiring.  Make sure the power leads have not come loose (as that could also cause heat and fire risk too) at both the PSU end and the connections to the Einsy board.
Posted : 31/01/2025 10:44 pm
Burcadus
(@burcadus)
Thanks Neophyl. This morning I checked all those connections on both sides, nothing loose.
The machine resetted again during the weekend.
To narrow down the possible causes, I was printing from a SD card (yes, I changed the SD card too) instead of Octoprint but Octoprint was still connected since I wanted it to log the events.  I just launched another print (a very long one) and I unplugged Octoprint from the machine to see if it will impact but, to be honest, I don't think it's the cause...
Posted : 03/02/2025 2:53 pm
Burcadus
(@burcadus)
The trouble did not reappear yesterday but I don't think it is solved yet. I might order some parts (since we have many MK3S, spare parts won't be a waste). What would be your guess as what I should replace first?
Posted : 05/02/2025 3:05 pm
