Printer Plate Damage
I printed a thing last night. When it was complete, I took the plate off the hotbed and set it aside to cool. This morning I removed the printed part and a piece of the surface came off with the part. Now I have a half-inch by quarter-inch oval that's damaged. I can feel the adhesive that was holding it down. The other side of the plate is undamaged.
Can this be repaired? I've only had this printer a few months.
RE: Printer Plate Damage
You can strip off the pei sheet and replace it with a new one. However it is VERY difficult to remove. Getting rid of the left over adhesive is messy as its really good at its job normally. Personally I would just flip it over and print on the other side and buy a replacement sheet as a spare.
Out of curiosity what filament were you printing ? I hope you used one of the barrier methods to reduce adhesion if it was something like petg or one of the other 'sticky' types of filament.
So I'm just out and have to buy a new sheet. Great. How much does that cost?
You don't have to rush out and get a new sheet. A properly cared for surface will last for years with little deterioration of performance. I have been using one side of my sheet for 2.5 years and it is as good as new. I have never used the other side.
In the meantime you can use the damaged side for small objects than can be placed to avoid the damage or for testing. I have seen postings where people have suggested/used Kapton tape to cover damaged area. Tape will show on bottom of print.
As Neophyl noted a barrier layer is needed for some materials to protect the sheet.
https://help.prusa3d.com/en/materials has a lot of information/warnings on printing with different materials.
Kenn
Quality is the Journey, not the Destination. My limited prints->
As kennd says, its a learning experience. I bought my mk3 (not s) over 3 years ago and took a small chunk out of it very early on with petg. Pretty much the same as you. I hadn't read the manual properly about using an adhesion inhibitor with certain filaments on the smooth sheet.
I am still using the other side of that sheet today. I bought a replacement pei sheet and also a spare complete sheet about 2 years ago while ordering other stuff from Prusa and they are still in the bubble wrap. I do occasionally use the damaged side but not very often.
I can tell you that I have never made that mistake again. Sometimes (most times) its the mistakes that teach you more.
The other thing is the print sheets are classed as consumables by Prusa. But a properly taken care of will (and has) lasted years and its not showing any signs of stopping.
Happened to me a few days ago. Tore off about a 2 inch piece. Just ordered a new Fysetc (Fystec?) sheet which should be here Friday. Still the other side is still good.
Someone said that you can replace the surface coating. I don't know if I will try that or not.
Well, thank you, all. I gotta figure out this non adhesion barrier we're talking about.
Merry Christmas
Been there, done that, unfortunately.
A week or so after I got my printer I printed an ABS print which would not budge from the plate. I was not experienced printing on the PEI surfaces at that time.
I got impatient and used a kitchen implement (small spatula) to pry it off and a couple of pieces of the PEI coating came off with it. Lesson learned the hard way. See the boo-boos to the left and rear of the print below.
I can still use that side for smaller prints, and, of course, the other side is good.
I know that some users have successfully re-skinned the plates, carefully removing the remaining PEI with a solvent (limonene?) and re-applying adhesive-backed PEI sheets to it. I have yet to try it, though I might when the 'good' side of that plate gets more boogered up.
