Printer get BIG offset in printing.
Mullcom
(@mullcom)
I put in logs and some Image to see if someone can figure out this.
I did have logs from octa print but this forum Delit them before i post the first topic. Its really bad forum and hard to work with when time is less then 5seconds befor somting other need to be done. Mobile comparability problems and uploading files is two things that hard to work with.
The first print!
https://1drv.ms/u/s!AgbscX10FlNOiCv9DUvIvEl36lzW?e=VE5G7o
Same with second print.
Opublikowany : 07/04/2020 5:05 pm
