Printer gcode message before printing
Nathan Goldsmith
(@nathan-goldsmith)
Hello I just purchased a used i3 MK3s+ 10th anniversary edition ( #698). I also have a Prusa mini. I added the printer to Prusa slicer but every print gives me a gcode not for this printer error.  THis is inserted into the Notes under Printer Settings....
Don't remove the following keywords! These keywords are used in the "compatible printer" condition of the print and filament profiles to link the particular print and filament profiles to this printer profile.PRINTER_VENDOR_PRUSA3DPRINTER_MODEL_MK3S
Any ideas? Printer works just fine.
Opublikowany : 03/01/2023 2:49 pm
I take it you selected the MK3 when you sliced the gcode file ?  Just adding the printer to the list in Prusa Slicer is not enough, you need to slice it specifically for the intended printer.   The gcode header has the printer type it is sliced for in it which is why you normally get the warning if the gcode file is not sliced for the correct printer.
Normally we ask for a zipped up project file for debugging purposes but in this case zipping up the gcode file you tried and attaching it would let someone check what printer it was sliced for.
Opublikowany : 03/01/2023 4:52 pm
Nathan Goldsmith
(@nathan-goldsmith)
RE: Printer gcode message before printing
Gotcha. Yes its sliced for the mk3, here is a link to an exported gcode:
https://drive.google.com/file/d/1mdagH2auRZckdqa0_etzm0PgN0zcF2hf/view?usp=sharing
Opublikowany : 03/01/2023 5:59 pm
It's sliced for a Mk3, not the Mk3S. Use the install wizard to install the proper printer model and slice again.
Opublikowany : 04/01/2023 4:39 am
1 ludzie polubili
