Printer didn't put the perimeter on my model.
paulcollett
(@paulcollett)
See images below, I have a model that I just printed and the external perimeter didn't print at all. You can see in the second image from PrusaSlicer that there should be sides on the model. The printer simply didn't print them at all. What's up with that? Any ideas?
Publié : 09/10/2019 3:58 pm
rmm200
(@rmm200)
RE: Printer didn't put the perimeter on my model.
You are going to need to post your stl file (zip it up).
Information about material and temperatures would help too. You have a lot of cobwebs...
Publié : 09/10/2019 8:09 pm
Dave Avery
(@dave-avery)
it looks like the outer perimeter didn't stick to the bed and then you got a blob dragging around and catching on the corner as each layer was printed
Publié : 09/10/2019 8:15 pm
paulcollett
(@paulcollett)
Printing with PLA Prusa Galaxy Black, default 215 temperature. Attached STL file: CAST 4A BOTTOM
The printer was literally not even going through the motions of doing the perimeter. I was watching it and the printer just didn't do that step.
Publié : 09/10/2019 9:21 pm
Actually - I'd like to see the entire table set: so export a full .3MF of your table/project.  That will tell us a lot more than just the model.
Publié : 09/10/2019 9:46 pm
Here's  a slice to try:
Gcode_to_try
Publié : 09/10/2019 9:50 pm
