Print pausing frequently to “Heat”
I’ve been successfully printing a variety of materials on my Mk3 for several months now. 3D noob.
FW 3.5.0, Slic3r PE 1.41.2 Taulman Bridge profile for current print, used successfully for smaller jobs.
Today, 50% thru a 6 hour nylon print, the printer started pausing every 15 to 45 seconds. Message on the screen says “Prusa i3 Mk 3 ready” then “heating”. Then print resumes after 5 seconds or so. . Extruder at 250, bed 90, no variations on screen. Printing in enclosure operating at 36% humidity and 29C. Filament pulled directly from an 8 hour dryer session.
I’d really appreciate hearing how to fix this.
Thanks
Re: Print pausing frequently to “Heat”
Per chat suggestion I reverted FW to 3.4.0, seems ok.
I womder if this is the same as i saw..
Was it Prusa who told you to go back to 3.4? If so, does this mean they acknowledge that this is a problem?
I am seeing the same problem on my MK3 after updating to the latest firmware.
I have exactly same problem ( https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f61/random-stoppages-for-heat-up-t26494.html )
Downgrade firmware to 3.4.2 does not help. Will try to 3.4.0
