Print fans available on amazon uk
Chocki
(@chocki)
Just let you know, the 5v 3 wire blower print fans appear to now be available on Amazon.co.uk
https://www.amazon.co.uk/FYSETC-Cooling-50x50x15mm-Radiator-Accessories/dp/B07NQHKF3X/ref=trb_chk_auth?keywords=prusa&qid=1552554533&s=gateway&sr=8-20&openid.assoc_handle=amazon_checkout_gb&aToken=Atza%7CIwEBIAtyY-_QlJ5tzw8AaiASWm3X6_rmvnNtjwImBhPQQhsavSQX6M3Hlnbzuz7k64AG47Xu_4K0Qhj5DTw6_BeIc5tICYuf6LQjNDCaQ6n-UF2540FhzCuLnxDYh7esP_nciS4F8GOk6jGWf9xaIqfQlnkv7w3ux8DflGXxwQT8M-eElIiisfl5oPNHEfCpJ9xowXxjxNh1KrmAZd-iLz3j4SNsgz4rabP5jCKQhr0uqRJzjJSiN50ilENV5fjt2WYs3_d-aZMueJTlVe8WlK4EH6UysVnjMFSmt5YU1PwCchXf1tbDW-HaQNHs4w3ylOFkBCMEizCrjmzPc4gmHffz_or5yBiWtbLvpCuHHxwUSAwoo6XTxES5MbThvlFuLmd00ZuafdoFSJ8tBSFV2evTsZnWbRps2nnTYmlwgd_zpMjEKvnxWA4xEbx1VxBGuKBWC8w_q5zEqk1GkW5L4cMY0id5ED1FCScKy-9OE8l3cveXsQ&openid.claimed_id=https%3A%2F%2Fwww.amazon.co.uk%2Fap%2Fid%2Famzn1.account.AGKE4SAY2XIWLBH4TJTEEKRCDONA&openid.identity=https%3A%2F%2Fwww.amazon.co.uk%2Fap%2Fid%2Famzn1.account.AGKE4SAY2XIWLBH4TJTEEKRCDONA&openid.mode=id_res&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0&openid.op_endpoint=https%3A%2F%2Fwww.amazon.co.uk%2Fap%2Fsignin&openid.response_nonce=2019-03-14T09%3A10%3A21Z7780972372309608860&openid.return_to=https%3A%2F%2Fwww.amazon.co.uk%2FFYSETC-Cooling-50x50x15mm-Radiator-Accessories%2Fdp%2FB07NQHKF3X%2Fref%3Dtrb_chk_auth%3Fkeywords%3Dprusa%26qid%3D1552554533%26s%3Dgateway%26sr%3D8-20%26trb_auth%3D1%26trb_open%3D1%26trb_sid%3D260-1238568-9062364&openid.signed=assoc_handle%2CaToken%2Cclaimed_id%2Cidentity%2Cmode%2Cns%2Cop_endpoint%2Cresponse_nonce%2Creturn_to%2CsiteState%2Cns.pape%2Cpape.auth_policies%2Cpape.auth_time%2Csigned&openid.ns.pape=http%3A%2F%2Fspecs.openid.net%2Fextensions%2Fpape%2F1.0&openid.pape.auth_policies=AmazonMultifactor&openid.pape.auth_time=2019-03-14T09%3A10%3A21Z&openid.sig=3Mio0i6ycWUlc5eecaZt2X9bIVBx%2Bbg0kSu70HOQhoY%3D&serial=&siteState=%7ChasWorkingJavascript.1
I have ordered a pair and will try them out over the weekend.
Opublikowany : 14/03/2019 10:13 am
Olef
 Olef
(@olef)
Re: Print fans available on amazon uk
Useful, thanks! 🙂
Opublikowany : 14/03/2019 12:14 pm
Looks like they're available on Amazon in the US as well. Good find, thanks.
Opublikowany : 14/03/2019 3:31 pm
vintagepc
(@vintagepc)
They also have a 4010 hotend offering but I cannot find any specs on it... (noise, CFM, static pressure). Shame.
Opublikowany : 14/03/2019 3:45 pm
Texy
 Texy
(@texy)
Good find, but shame you are forced to buy two at once...
Texy
Opublikowany : 15/03/2019 8:18 am
richard.l
(@richard-l)
Member Moderator
Texy
Actually works out well for me. Have a spare for each printer.
Opublikowany : 15/03/2019 6:19 pm
vintagepc
(@vintagepc)
Texy
There's also a set with one print fan and one hotend fan.
Opublikowany : 15/03/2019 6:27 pm
Chocki
(@chocki)
Also a PINDA sensor Mk2 as found on the Mk3, and a filament sensor.
I just typed PRUSA into the search bar at amazon and nothing more.
the 4010 fan is this one if you want a genuine Noctua fan, but you may have to alter the wiring.
https://www.amazon.co.uk/Noctua-NF-A4x10-5V-3-Pin-Premium/dp/B00NEMGCIA/ref=sr_1_1?ie=UTF8&qid=1552675457&sr=8-1&keywords=noctua+40mm+5v+fan
What I can't seem to find readily available are POM T8x8 nuts for the Z axis (Hint Hint ❓ ), there is one available on Amazon, but in general they seem to be quite rare.
Opublikowany : 15/03/2019 7:53 pm
