print bed wobbles rotationally - MK3s
Tim G
(@tim-g)
I have an MK3s that's been giving me some crappy prints lately. Just noticed that the print bed can rotate a few degrees around the z-axis.
is this normal?  If not, how to I fix it?
Opublikowany : 17/01/2021 7:07 pm
RE: print bed wobbles rotationally - MK3s
Not normal.  Check your u-bolts.
Opublikowany : 18/01/2021 3:59 am
Tim G
(@tim-g)
thanks, that seems have fixed the wobble.  trying a test print to see if things are better.
Opublikowany : 18/01/2021 7:16 am
sakabug
(@sakabug)
Are you using plastic bearings? They are slack and they will allow rotation. Don't use them.
Opublikowany : 20/01/2021 4:47 pm
