Print Bed Staying on after print is finised
JOHNBOY66
(@johnboy66)
I woke up this morning to and checked my print.  Print looked great.  But I had a print bed time out alarm.  I noticed that with the lastest update it does not shut the print bed heater down when finished.   Is there a setting in the Prusaslicer to disable this?    I am using Prusaslicer 2.1.1+  and have firmware 3.8.1 in my MK3.    I am using the Prusa PETG settings in PrusaSlicer.   Also seems the nozzele purge across the front of the build plate is no more.  I added 2 extra skirt loops to purge the nozzle.    Printer is printing fine other wise.
Opublikowany : 14/12/2019 10:38 am
JOHNBOY66
(@johnboy66)
RE: Print Bed Staying on after print is finised
I just went and compared two codes I posted.   The code posted with the latest PrusaSlicer  Does not have a M140 S0 ; turn off heatbed after it shuts off the nozzle heater.  Is there somewhere in the PrusaSlicer setting I can turn the heat bed back off after printing?   I looked but have not seen it.
Opublikowany : 14/12/2019 1:11 pm
Yes it us in the custom gcode end code under the right hand drop down menu (Printer. I think)
Not at home at moment
Joan
Opublikowany : 14/12/2019 8:21 pm
Joan
Opublikowany : 14/12/2019 8:22 pm
JOHNBOY66
(@johnboy66)
@joantabb
Thank You!
I see it now!
Beginning and end code and end code are very different from 2.1.0+ to 2.1.1+
Code Flavor changed also I see.
This post was modified 6 years temu by JOHNBOY66
Opublikowany : 14/12/2019 8:52 pm
@john-m-jordan-joy-j
I have not looked at the  new slicer yet!
Joan
Opublikowany : 14/12/2019 9:06 pm
JOHNBOY66
(@johnboy66)
@joantabb
I did not realize I had different versions on my laptop and PC.   So the difference in start up procedure and the heat bed not turning off caught me off guard.   File naming when posting gcode is different also.  I like the old way better.
I added the code for the purge and the heat bed shut off in the Custom Gcode windows.  Printing at the moment.   Start up procedure was as before with the nozzle purge on the front left corner of the print bed.
Thanks again for your help!
Opublikowany : 14/12/2019 10:04 pm
