PowerPanic does not work properly (for me)
jonnieZG
(@jonniezg)
Hi! I am trying to test the PowerPanic feature, as described in the Prusa video:
  • Started a print from an SD card
  • During a print switched off the printer using a switch on the power line (NOT the switch on the PSU)
  • Turned the switch back on
  • The head re-homes and heats the bed and the nozzle
  • The head goes back to the position where it was in the moment the print was interrupted
  • The print does not resume. The head just stays there, while the heaters are on.
  • Firmware: 3.2.1-576
    Postato : 24/05/2018 5:21 pm
    mklabunde
    (@mklabunde)
    Re: PowerPanic does not work properly (for me)
    I thought that you had to press the button on the display. I thought I read that it will come up on the display asking if you want to resume the print. I could be wrong.
    Mark
    Postato : 24/05/2018 7:41 pm
    devilhunter
    (@devilhunter)
    I think the power panic logic in the PSU sees if you push the on/off switch or if you are pulling the plug.
    Pushing the button on the power line is the same as pushing the on/off button on the prusa, the power lines can only break one mains wire. (phase)
    Neutral and Ground still get through to the power panic board.
    A power outage or a power cable pull results in all 2 main lines cut. (phase + neutral)
    I don't have a power panic board in my clone so i can't check, but here's the power panic board, if someone can make more sense of of it than me.
    https://github.com/prusa3d/MK3_Power_Panic/blob/master/rev.04/power-panic.pdf
    aka, pull the AC cable dude
    Postato : 24/05/2018 9:22 pm
    jonnieZG
    (@jonniezg)
    Thank you for the elaborate explanation, but pulling out the plug is said (by Prusa) to be a bad option for testing the PowerPanic, since it induces arching which might trigger the panic event multiple times. Nevertheless, I tried also that, but it didn't work either (produced the same result).
    Postato : 25/05/2018 9:15 am
    devilhunter
    (@devilhunter)
    Page 36 of the manual ( https://www.prusa3d.com/downloads/manual/prusa3d_manual_mk3_en.pdf ) says
    Power panic doesn't work if you interrupt the print with the on/off power switch.
    PP is off in your settings menu perhaps?
    If that ain't working, then this should be a issue for the Prusa Chat. (they will tell you to upgrade the FW and do a factory reset)
    Postato : 25/05/2018 5:50 pm
    jonnieZG
    (@jonniezg)
    I am not talking about the switch on the PSU, but the switch on the extension cord. I followed exactly the procedure shown by Prusa: and it still does not work.
    I could not find that setting in the menu.
    I talked to them, but they recommend testing with their original gcode. 😆 I will do that tomorrow, and then I'll have a nice chat again with the support.
    Postato : 25/05/2018 10:18 pm
    Protoncek
    (@protoncek)
    I can confirm this situation - does exactly the same here: heating, head goes to last position and stays there, nothing happens.
    Power panic DOES NOT work in 3.2.1...
    Also occasional bed leveling fail occurs...
    Postato : 26/05/2018 12:07 pm
