power wire connector size
im trying to build the lack table enclosure and got the black power supply and the power wires are too short i need to make my own not too hard. ill be using 14awg wire and some XT60 but i cant seam to find the size of the forked connector prusa uses on the power supply and board its ether a #8 or #10 stud i cant find any docs that tell me witch one it is
Posted : 18/04/2019 4:24 pm
Re: power wire connector size
Definitely smaller than a 10.
Posted : 18/04/2019 4:54 pm
RE: power wire connector size
If you look at Step 12 in the guide it references an M3 x 10 screw on the heatbed cable assembly
3m Publish a stud size/mm and metric nut table here
https://multimedia.3m.com/mws/media/65460O/terminal-stud-size-chart.pdf
I reckon you want a #5 which is 3,175 mm connector to fit over an M3 nut (3mm)
Posted : 19/10/2020 10:31 am
