Power supply ticking when extruder heats up
Malibusteve
(@malibusteve)
Power supply ticking when extruder heats up - Does anyone else have this issue? It goes away when it gets to temp but occasionally ticks, when I assume the extruder needs to heat up again. It's happened ever since the day I received it assembled. I assumed it would go away for some reason. Now, it's getting a little annoying. It's not that loud but it is noticeable. It' annoying but if it's not a big deal and nothing is wrong, I can deal with it. Thanks in advance for any help
Napsal : 29/11/2018 7:22 pm
Patrick McNamara
(@patrick-mcnamara)
Re: Power supply ticking when extruder heats up
Do a quick search on the forums and it will answer the question as to whether others are seeing it... 😀
Napsal : 30/11/2018 4:04 am
Perfectly normal - it's from the bed or hotend power circuits switching on an off to control temps. My guess is it's magnetic fields coming and going.
Napsal : 30/11/2018 4:44 am
