Power Supply OEM Part Numbers
A rather long time ago someone found the actual power supply manufacturer and model for the MK3 SILVER power supply:
T-Led TLPZ-24-240
Has anyone found the same for the BLACK power supply?
Respondido : 17/11/2019 7:38 pm
rmm200
(@rmm200)
RE: Power Supply OEM Part Numbers
Did that manufacturer include the power lost signal, or did Prusa add it? On the black, it is integrated.
I really wish there were a board I could add to my Meanwell...
Respondido : 17/11/2019 9:42 pm
I have no idea if the Power Loss if coming from the Prusa made add-on board (as it is in the silver) or something from one of the Meanwell designs (they have several models with various 'extras' like power fail, over current notification, etc.
https://www.meanwell-web.com/en-gb/closed-frame-power-supplies/all-technology/24/all-output-current-a/240,350/universal-input-110-230v/
E.g.,
HRP-300-24 has a DC_OK pin that could be used as a power fail.
SPV-300-24 has a DC_OK pin that could be used as a power fail, and a RC pin that appears to be a reset/power down.
Esta publicación ha sido modificada el hace 6 years 2 veces por --
Respondido : 17/11/2019 10:10 pm
On the SVP, another though is it's a remote control for the 20-100% voltage setting ... probably what it actually is.  Without diffing deeper I'm guessing a bit.
Respondido : 17/11/2019 10:16 pm
If I ever decide to upgrade, I'll probably use this beast:
https://www.meanwell-web.com/content/files/pdfs/productPdfs/MW/HRPG-300/HRPG-300-spec.pdf
Respondido : 17/11/2019 10:21 pm
Anyone know the true and accurate power supply part number for black power supplies being shipped with the MK3S ?
Respondido : 18/11/2019 8:40 pm
