Power supply failure
peter.b40
(@peter-b40)
I have had my Mk3 up and running properly for about 5 days. Today the power supply went bang, slight smell of burning, and all power lost. Has anyone else had an issue with the power supply? It had been at the end of a long run.
Where do I get support from, technical drawings, warranty support etc?
Napsal : 21/07/2018 5:48 pm
peter.b40
(@peter-b40)
Re: Power supply failure
Further investigation shows that the fuze has blown. What are the specs for the fuze in the housing just above the power lead>
Napsal : 21/07/2018 9:12 pm
Olef
 Olef
(@olef)
The fuse probably blew because of a fault in the PSU. Replacing the fuse will not fix the fault.
Are you on 110v?
Search the forum for PSU failure. Somewhere around here is a thread of some 40-odd pages... And if the printer is only a few days old you need to chat to support from the Prusa shop page.
Good luck!
Napsal : 21/07/2018 10:05 pm
peter.b40
(@peter-b40)
No, I am on 220 volt, I work in Belgium.
Napsal : 23/07/2018 9:19 am
Olef
 Olef
(@olef)
Interesting, most fails have been 110v. Definitely chat to support!
Napsal : 23/07/2018 12:59 pm
