Power off procedure
doru.cazan
(@doru-cazan)
Power off procedure
Assembled my new printer and successfully printed the Prusa logo. Unloaded the filament (in preparation for storage) and let the printer to cool (all sensors showing about 30 degrees Celsius). Then I power down the printer using the power supply switch.
When I powered up the printer I noticed that the number of power failures was increased. Was I following correct power off procedure? If yes, where I should check for the issue. If not, what steps I missed?
Thanks,
Doru
Opublikowany : 11/08/2019 2:54 pm
doru.cazan
(@doru-cazan)
RE: Power off procedure
While still looking for the answer I have found this:
https://github.com/prusa3d/Prusa-Firmware/issues/1929
It seems that this is a bug in the firmware; hope will be fixed in the next firmware release.
Thanks,
Doru
Opublikowany : 11/08/2019 3:03 pm
Prusa development, say that this will be fixed in firmware 3.8, but didn't say when 3.8 will be released
Jpan
Opublikowany : 11/08/2019 9:36 pm
Dave Avery
(@dave-avery)
3.8.0 RC1 is on github for the brave https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.8.0-RC1
Opublikowany : 11/08/2019 11:08 pm
