Possible Motherboard or Screen Failure
Bruce
(@bruce-2)
Any advice on troubleshooting a possible motherboard or screen failure. I was starting a new print on my MK3S and random stuff seemed to appear on the screen. rebooted and it seemed to be OK then as I pressed the dial the screen went blank and it seemed to shut down. Tried cycling the power switch but got no response on the screen. Power supply is delivering 23.6 volts to the motherboard and the three fuses all test OK. Pressed on all the connectors and they all seem to be firmly plugged to motherboard. My motherboard is marked ENINSY RAMBo 1.2b. Is there any procedure to trouble shoot and determine what is the problem? Of course I've had a 5 extruder XL on order since they were announced. Thanks for any help anyone can offer.
Publié : 23/06/2023 10:06 pm
Pull and reinsert both ends of the display ribbon cables.
Publié : 23/06/2023 10:55 pm
Bruce
(@bruce-2)
RE: Possible Motherboard or Screen Failure
No joy unfortunately.
Publié : 24/06/2023 12:40 pm
Are you able to do a factory reset?
https://help.prusa3d.com/article/factory-reset-mk2s-mk2-5s-mk3s_2216
Publié : 24/06/2023 2:40 pm
