possible bug in firmware
Maurice Heskett
(@maurice-heskett)
I'm experiencing a high rate of failure due to what I think is a bug.
The gcode for home_all, and the crash recovery rehome of just XY, gets a different X home, by 1 full step (or more, it is consistent) to the left on the build plate
when recovering from a crash. This results in a throwaway part, and I have a 13 gallon kitchen trash bag full of throw aways.
Can this be addressed in the RAMBo firmware? Please?
Take care & stay well
Gene
Respondido : 02/08/2022 4:06 pm
RE: possible bug in firmware
Hi Gene.
this may seem abstract.
Have you tried lubing the rods? and checking for contaminants on the smooth rods?
Friction can cause inaccurate homing
Respondido : 02/08/2022 6:56 pm
This is a user-to-user support forum, and the devs don't hang out here much (or at all). You probably want to go to Prusa's GitHub site and open a ticket there.
Respondido : 02/08/2022 7:13 pm
Maurice Heskett
(@maurice-heskett)
first and 2nd things I checked, its very smooth, no catches or drags anyplace.  Thanks Joan.
Respondido : 02/08/2022 9:41 pm
Maurice Heskett
(@maurice-heskett)
Also, I can't log onto github, I've had a crash and had to start with a new install, and they won't let me in from my fixed address because I no longer have the username and password, no aliases but they recognize the only name I've used and won't let me re-register. I can't even post a help me login msg because you have to log in to send the msg.
Respondido : 02/08/2022 9:50 pm
gudnimg
(@gudnimg)
Any chance you could write a few steps on how to reproduce this? I might be able to fix it for you.
Respondido : 13/09/2022 7:41 pm
Maurice Heskett
(@maurice-heskett)
no context. If you are referring to my inability to login to github, I assume its because my username (WOWELECTRONICS) is previously registered and with two spinning rust drive failures in short order last fall, I've absolutely no clue what my password might have been.  But because my address is non-volatile and associated with my email, I can't get in and they will not allow me to create a new account. If everything github knows about gheskett@shentel,net and WOWELCTRONICS was wiped clean from their system, I might stand a chance of creating a new account and joining the party. Until then its a lost cause.
Respondido : 13/09/2022 9:33 pm
gudnimg
(@gudnimg)
No I’m not referring to Github but the original issue you posted here. What steps do I need to perform to recreate the issue?
Do you use Octoprint or SD card to print?
This issue on Github sounds similar https://github.com/prusa3d/Prusa-Firmware/issues/3460
Respondido : 13/09/2022 9:40 pm
Maurice Heskett
(@maurice-heskett)
And its not possible to send a message to github w/o logging in. I've sent 5 or 6 passwd reset requests, all ignored. Typical for m$. And guess who owns github...
Thanks for checking Joan,I appreciate the effort.
Respondido : 14/09/2022 9:38 pm
