Please Check: Axis Length - Axis Y
jtandrew
(@jtandrew)
Good morning (or whatever time it may be for you),
I have an MK3s that I have had for about 14 months.  I was able to get all of my settings working fairly well last year and I have not printed anything in a couple of months.
I turned the machine on a few days ago and went to run a print and the Y-axis is getting stuck.  I am getting the message:
Any help in what I may need to look at would be helpful.
Thanks!
Jim
Best Answer by jtandrew:
It appears it was the same issue I had about 9 months ago.  I needed to lubricate the Y axis and while I did that I did it for the others ones as well
Napsal : 21/01/2021 2:51 pm
1 lidem se líbí
jtandrew
(@jtandrew)
RE: Please Check: Axis Length - Axis Y
Napsal : 22/01/2021 8:06 pm
CoyotesOvernight
(@coyotesovernight)
I had the same problem after two months of sitting, and this was also the solution for me. In addition: I increased the tension on the Y-axis belt on the bottom of the heat plate.
Napsal : 29/01/2023 11:41 pm
