PLA blob of death - need to replace thermistor, heater bock, etc.
Bentonville Heart Lites 3D Printing
(@bentonville-heart-lites-3d-printing)
I had a catastrophic failure with PLA blob around the hotend. I screwed up fixing it and damaged the thermistor leads as well as the cartridge leads.  I now need to replace the heat break, heat block, thermistor, and cartridge.  Do you know if the following will work with MK3S/MMU2S?  (I tried to use an Amazon replacement from when I had an Anet A8 but that keeps blowing fuses so I'm guessing I need the "real" replacement for the MK3S.)  Thank you!
Respondido : 26/06/2019 6:31 pm
Nikolai
(@nikolai)
RE: PLA blob of death - need to replace thermistor, heater bock, etc.
Sorry to hear that. It happens pretty often. Usually you can scrap the heat break and heater block. Just use a heat gun or any heat source to bring it up to ~60-100C temperature. You should be able clean up everything.
So you should only need a new heater cartridge and thermistor. I prefer printed solid over matterhackers but both should do the job:
https://www.printedsolid.com/products/e3d-replacement-heater-cartridge
https://www.printedsolid.com/products/prusa-mk2-mk3-thermistor-cartridge
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 26/06/2019 7:15 pm
1 les gusta
Feday
(@feday)
Remember that if you have the MMU that the heat  break us not the same as the default one from e3d... Where you can get the prusa specific one I don't know though. Without MMU the normal heat break is fine, possibly even better then the prusa modified version.
Respondido : 01/07/2019 6:00 am
