PLA blob of death - need to replace thermistor, heater bock, etc.
RE: PLA blob of death - need to replace thermistor, heater bock, etc.
Sorry to hear that. It happens pretty often. Usually you can scrap the heat break and heater block. Just use a heat gun or any heat source to bring it up to ~60-100C temperature. You should be able clean up everything.
So you should only need a new heater cartridge and thermistor. I prefer printed solid over matterhackers but both should do the job:
 https://www.printedsolid.com/products/e3d-replacement-heater-cartridge
 https://www.printedsolid.com/products/prusa-mk2-mk3-thermistor-cartridge
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Remember that if you have the MMU that the heat break us not the same as the default one from e3d... Where you can get the prusa specific one I don't know though. Without MMU the normal heat break is fine, possibly even better then the prusa modified version.
