PINDA Setup question
Marc
 Marc
(@marc-3)
Issue: I have been running the setup Wizard after a nozzle change. When the 4 calibration points process is running, my nozzle contacts the paper at Point 1. I have shut off the machine and reran the Wizard four times. After checking my PINDA height in relation to the nozzle, see included picture, I'm wonder what I missed.
Configuration:
Printer: Prusa i3 MK3S assembled by myself
Deviations from standard: None. Standard 4 mm nozzle, PRUSA PLA filament, PRUSA slicer
Case description:
The machine can't complete the setup wizard without touching the paper.
Slicer: N/A
Filament used: N/A
Printer setup: standard
Print setup: no enclosure, sits on a shelve in the basement. Temp 73 F and 37% humidity.
Attach files: N/A Nozzle to PINDA sensor relationship.
Coincidence: I just performed a nozzle change
Publié : 26/10/2020 9:56 pm
RE: PINDA Setup question
You must read the instructions. They explain what you must do to keep the nozzle from scraping.  Too long to reproduce here. But those Z lead screws must be turned to adjust for the bed conditions.
And - the PINDA looks much too high -- too far from the bed. Desired height is 0.8 mm to 1.2 mm (I'd have to look it up).
Ce message a été modifié il y a 5 years 2 fois par --
Publié : 26/10/2020 10:31 pm
Marc
 Marc
(@marc-3)
Thank you Tim.
In following your advice to lower the PINDA sensor, it seems to have addressed the issue.
Thank you
Marc
Publié : 26/10/2020 11:51 pm
1 personnes ont aimé
