PINDA broke redundantly due to warping ABS
molymp
(@molymp)
I recently built an enclosure to be able to print ABS. This worked fine for ~ 100 print hours (stable temperature ~42°C). But during the last print, one part on the bed began to warp.
As a result, the PINDA mounting and the parts fan duct broke as well as the PINDA itself broke (the plastic tip was ripped off and was melted into the ABS part...).
Luckily I did print the relevant parts a few weeks ago so I was able to repair this part. Fun fact: the next print would have been: Fan duct in ABS 😉
For the PINDA, I was able to extract the tip from the ABS and just placed it back to the metal shaft.
With that I hoped that I may print again. But when I tried to run the self-test and re-calibration, I got an error message. After the (successful) fan test, the z-axis was moved ~ 1cm up and then the test stopped with "Selftest error! Please check: Endstops / Wiring error Z".
I already placed an order for a new PINDA but would like to get a better understanding
1) If this error message indicated a broken PINDA or if I may expect another issue,
2) How exactly the PINDA is set-up, what exactly is broken, if I have a chance to repair it
3) How I may avoid this in the future. I mean, I cannot 'prohibit' ABS from warping, but maybe there is already a good idea for e.g. a 'PINDA self rescue' mechanism?
Anyone else who had a double-broken PINDA issue?
Postato : 04/07/2020 9:00 am
molymp
(@molymp)
RE: PINDA broke redundantly due to warping ABS
If you ever wondered: this is what a PINDA looks like from inside 😉
Not sure what's inside the tip and if 'it' was connected to the small pcb other than by the glue...
Postato : 04/07/2020 9:59 am
Peter M
(@peter-m)
The extruder can only cool enough till 35C degrees, if you enclosure gets hotter, you need to cool a little.
And the pinda holder I would print in ABS, and/or search for a stronger part if somebody already made one.
A extra cooler on top of extruder I would also do(see thingiverse), you have a enclosure, the extra fan i would do it will cool the motor very good.
Printer is not made for in a enclosure so keep checking temps.
Questo post è stato modificato 6 years fa da Peter M
Postato : 05/07/2020 10:02 am
molymp
(@molymp)
@peter-m26
Thanks, did not know that detail with 35°C. I already moved the PSU outside the enclosure and have an additional heatsink on top of the extruder - only by intuition, now I know why...
To be very open, I only need the Prusa to print ABS until I have all parts for my VORON complete 😉 Later it would be dedicated to PETG and PLA only.
For checking the temperature, I have an Arduido-based temp control that would open a small lid with a servo when 45°C are reached - did not happen so far. Do you suggest to hold the temperature at 35°C? I read that 45-50°C would be better for ABS prints.
Postato : 05/07/2020 12:17 pm
Peter M
(@peter-m)
If printing works you can leave it how it is, if have none filament melting higher up in the extruder, a little higher is possible no problem.
Postato : 05/07/2020 4:28 pm
