Pin 73 not working?
Hello everyone,
I have a problem regarding this article: https://blog.prusaprinters.org/how-to-make-3d-print-time-…/… I connected everything following the instructions and it worked great. Then I changed the EINSY enclosure, so I had to reconnect all the cables. Now the phone connects properly, but it looks like the trigger did not work. So I replaced all the cables what did not help. Next I reconnected them from the front to the back of EINSY – still, the trigger does not activate. I wonder if I could damage the pin on EINSY so I would like to plug this trigger into another pin. Is it possible to change pin activated with 5V (P73) to some other one?
Napsal : 05/07/2019 8:45 am
