PFTE length requirement with Copperhead heatbreak and block combo.
Bartgalok
(@bartgalok)
A friend of mine has an MK3S ( no MMU) and is replacing the Heat Break and Hot Block of his original Prusa E3D V6 with Copperhead versions. Does the PFTE tube length need to be adjusted as he is finding that the tube is about 4mm further away from the BondTech gear? It may not make much difference for PLA or PETG but for flexible materials it seems that it likely would pose a problem.
Has anyone had this issue? Should he prepare a longer tube or should he use the original Prusa PFTE tube?
Thanks for your help.
Napsal : 11/10/2020 6:39 pm
andrealaghi
(@andrealaghi)
RE: PFTE length requirement with Copperhead heatbreak and block combo.
interested due a similar upgrade setup
Napsal : 12/11/2020 11:45 pm
