Persistent Y-Axis Rattle on MK3S+
Criptop
(@criptop)
Hi everyone,
I’m trying to diagnose and resolve a persistent Y-axis rattle on my MK3S+ and would really appreciate some advice and guidance.
The video below demonstrates the rattle at it’s loudest/most consistent – when the Y axis is making rapid changes of direction.
https://www.youtube.com/shorts/nwqnRgaMw9Q
Symptoms
  1. Pronounced mechanical rattle/chatter from the Y carriage, perhaps stronger when the bed is in the back half of the carriage.
  2. The rattle is extremely pronounced during infill.
  3. It does not rattle at all during the movements of mesh bed levelling.
  4. The sound is mechanical, not stepper noise etc.
  5. Using a mechanic’s stethoscope to check the bearings, rods, motor and mount, belt path and y carriage frame. I’m 95% sure the noise originates from the left Y axis rod or something attached to it.
  6. Occurs mainly at slow or medium speeds or during frequent direction changes.
  7. Prints have VFAs, but no other quality issues.
Troubleshooting Attempts So Far
  1. Cleaned the bearings thoroughly with IPA, repacked them with lithium grease and also tested them separately with Prusa’s supplied lubricant.
  2. Replaced all three Y-axis bearings with Misumi bearings taken from another MK3 that runs quietly.
  3. Replaced the left Y-rod with a new one.
  4. Rotated the rod in the holders to test for straightness/tolerance variation.
  5. Loosened the rod holders and applied inward/outward pressure before tightening.
Throughout all of this, I have disassembled and rebuilt the entire Y-axis 5–6 time in total, following Prusa’s online build guide each time and performing the “bed slide alignment” procedure multiple times. Rattle persisted with all bearing sets, lubrication types and other attempts. The Y axis belt tension reads exactly centred in the optimal range using the PrusaMobile App. I haven’t tried DryLin bearings which I’ve avoided so far because many users report tolerance issues. Open to reconsidering if the community believes it’s the right next step.
Result: left Y-rod/bearings are the strongest noise source.
Clues
  1. Pressing on the bed reduces the noise
  2. If I press upward or downward on a corner of the heatbed during printing, the rattle diminishes noticeably.
  3. If I press from inside → outside at the front of the left Y-rod, the noise drops 60-70%. However, despite multiple attempts (loosening, repositioning, tightening), I cannot get the rod holders to stay in the position where the noise disappears.
Links
Some of the forum posts/videos of other users who have experienced the noise and things that I have tried:
  1. https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/rattle-noise/?__cf_chl_tk=nxrZ46QaHiztrMzpKFx1I2qxThusCGdfyOT9GmZ41ik-1754555869-1.0.1.1-O63uRSra1JYNln4wjlzqMFy863vzam8_3qwV4.41rYQ
  2. https://www.reddit.com/r/prusa3d/comments/lxrmce/prusa_i3_mk3s_bearings_rattling_problem/ https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/y-axis-bed-rattle-when-moving/
Thanks so much to anyone who can offer insight. I will happily try any other corrective measures, or retry any ones I’ve already attempted. I’ve put a huge amount of time into diagnosing this and would love to finally get it fixed. Any help is very much appreciated!
Best Answer by JoanTabb:
noises can be difficult to trace, the Prusa Mk4 has thin rubber pads and slippery nylon like pads between the bearings and the Y axis platform and it also has a pad between the motor housing and the back frame rail
the blue arrow points to the Rubber and the purple arrow points towards the plastic
Prusa use a thermal heatpad between the motor and the frame, probably because they already use this material on the buddy board.
I have used 1mm thick double sided 1mm foam adhesive strip on My Mk3...
these options may help! regards Joan
This topic was modified před 5 months by Criptop
Napsal : 26/11/2025 6:23 pm
RE: Persistent Y-Axis Rattle on MK3S+
Napsal : 26/11/2025 6:45 pm
1 lidem se líbí
Criptop
(@criptop)
Thank you very much Joan for your suggestion and assistance. Those are interesting options and they definitely are worth a try, I'll order some materials and see how it goes.
Thank you 🙂
Napsal : 28/11/2025 10:02 pm
Good Luck,
Joan
Napsal : 28/11/2025 10:57 pm
Robin_13
(@robin_13)
On my MK3, I cannot rotate the bearings when they are bolted to the frame with no changes to the original design.  As for rubber sheet, it doesn't get hot so you should be able to get some at an automotive or hobby shop.
I am almost suspecting the bearings are starting to fail.  I am going to replace my bearings with polymer bearings on my next maintenance schedule.
Napsal : 01/12/2025 6:59 pm
Criptop
(@criptop)
Hi All,
Just following up on this for anyone in the future. Further to my last post, I have disassembled the Y carriage and:
1. Packed the three original Misumi bearings with Silverhook High Temperature EP2 Lithium Grease
2. Installed 2mm silicone pads as described by Joan
3. Turned the Y axis carriage upside down during reassembly (i.e. rotating the carriage 180 degrees along X axis)
This has lead to an elimination of the rattle noise during normal movements, and about a 80% reduction of rattle noise during gyroid infill movements. I made the above changes all at once, so I can't be sure what improved the rattle. However, given that I have done step 1 before, I hypothesise that the y carriage frame may be slightly warped, so by turning it upside down, it may be warped in a different orientation such that the bearings are able to run more smoothly and/or that the silicone pads have helped to decouple the vibrations. Additionally, I'm inclined to think the bearings make the rattle noise, but are not the cause of the rattle noise.
The printer is now quiet enough that I can hear the infamous Y axis motor clicking/dim knocking sound, which I'll work on next.
The printer is certainly quiet enough for me for it to be tolerable. Thanks to Joan and Robin for your help!
Robin, how are you getting on with your printer?
This post was modified před 4 months 2 times by Criptop
Napsal : 04/01/2026 1:45 pm
