PAUSE to max Z HELP..
Rodger
(@rodger)
I am having Challenges and i cannot find a definitive answer i keep getting/finding the same un-helpfull advice.
 What i would like to have happen is when i am printing there is often a reason to pause the printer to correct an issue a "blob,leaning support ,dirty head ect" what i would like to have happen is when i press pause i would like the hot end to go up to max  Z  ,i would be content with that mod only "not sure why it is not the default reaction as i have no idea why you would pause otherwise? the current default action is to go a mere 30 up from current, "changing that was no help" if i just start a print then ....ugggggH.
ya i know about hot Z adjust but that is NOT the answer,that is a workaround ...an extra step yada yada yada
so i have tried lots of different things and to be honest ..i'm ignorant on this coding stuff as it never seems to do what i think and i have a sneaking suspicion i'm putting it in the wrong place anyways....but what do i know.
HELP.
Thanks in advance.
Publié : 04/05/2020 5:08 pm
