[Solved] Pause print issue with firmware 3.13.2 update
cabbage63
(@cabbage63)
Since the firmware update (and prusa slicer update) I am having issues with "pause print" .  I can set the pause in the slicer without any problems and when I print it will pause at the proper layer. The problem I'm having is when it pauses I cannot scroll down on the LCD screen to the  "unload filament" option, it's just not there. Half way through a print I reach my pause and I'm stuck forced to cancel the print unable to change filament. IS THIS A BUG? If it is it's a very annoying one only experienced for the past week or two since the firmware upgrade. Has anyone dealt with this as well? If so a response would be greatly appreciated! Not that this forum would have a bug fix for this but if others have experienced this, it needs to brought to the attention of technical support. Again any and all responses would be greatly appreciated. Thanks.
        C
Napsal : 26/12/2023 9:30 am
