Path to working filament sensor
timothy.d
(@timothy-d)
The filament sensor on my MK3? is useless and has to be disabled to keep from constantly tripping the filament change.  While watching the sensor output, it's clear that _any_ movement of the filament causes it to flip state.  I am using the older rev 0.1b sensor.
I would switch it out for the rev 0.4 sensor, but the version warnings on the purchase page "It is ONLY compatible with the MK2.5S and MK3S/MK3S+. It is NOT compatible with the MK2.5 and MK3" give me pause.
In 2017 I sold my MK2 and purchased a MK3.  I then purchased the MK3 MMU2.0 upgrade kit (which I _think_ included a MK3-MK3S upgrade).  I could never get the MMU to work reasonably and removed it.  I now have bags of different E-axis parts and cannot comfortably identify what's on the printer or what's in the bags.  Everything about my current printer works great except the filament sensor, which I really want to have working.
My Questions:
- Is there a straightforward way to identify which (MK3, MK3S, Frankenstein) E-axis extruder is on my printer now?
- What/where is the most advanced E-axis extruder available for the Prusa MK3X platform? (I'm happy to print parts.)
- What is the most reliable filament sensor configuration available for the Prusa MK3X platform (and does it have dependencies?) (example: 0.4 sensor on MK3S extruder)?
- Should I just buy the 'Original Prusa i3 MK3/S to MK3S+ upgrade kit'? to get to the best available filament sensor performance?
Thanks!
--Tim
Publié : 12/09/2021 7:29 pm
Membre
I would buy
I would buy the Mk3S+ upgrade.  It is more reliable than the sensor you currently have.  The upgrades are worth the cost.
Publié : 14/09/2021 10:04 am
timothy.d
(@timothy-d)
Thanks!
Thanks, I purchased one of the Rev 0.4 sensors and cable and printed a full set of the up to date MK3S+ extruder parts.  I  had a weird mix of versions (C1, D1, R1, etc.) in my parts bin and on the printer, so I'll start fresh with a clean MK3S+ rebuild.
--Tim
Publié : 14/09/2021 1:36 pm
