Partial Clog Purgatory
mpalframan
(@mpalframan)
My MK3S+ has had months of successful prints. At one point I got a full clog and replaced the PTFE tube. At another point I fixed a partial clog with a cold pull. Recently, I've had back to back to back partial clogs.
I tried a couple cold pulls, but the following print would fail a couple layers in. Finally I gave in and took out the PTFE tube, but it was clean. I put it back in and removed the nozzle and gave it an acetone bath and cleaned it out fully with the needle. I followed up with a first layer cal and backed off the first layer a bit.
Moment of truth: a small print succeeded!
Next print: failed on the second layer.
I'm not sure what else to try. The tensioning screw looks about where it always has been, and I'm using a filament that has worked fine in the past.
Any ideas? Thanks in advance.
Publié : 28/09/2022 7:21 pm
RE: Partial Clog Purgatory
Please show us one of the prints that failed.
Publié : 29/09/2022 12:52 am
mpalframan
(@mpalframan)
Top of failed prints
Bottom of failed prints
Ce message a été modifié il y a 4 years par mpalframan
Publié : 29/09/2022 1:05 am
