PA12 CF Nylon Nozzle Clogs
Victory Sports
(@victory-sports)
Hey Team!
Learn so much everyday 3d printing. Today I learned that the filament i'm using (Polymaker PA12 CF) clogs my nozzle. I know this because when I switched it the prints were good again. I did try to use that tool my Prusa came with to unclog it but was unsuccessful. The problem is I only got about 12 hours out of the nozzle and they cost a lot! Wondering if there were any pro tricks to get my nozzle working again? Thanks!
Veröffentlicht : 26/01/2023 1:40 am
Are you printing CF with a standard brass nozzle?  I'm surprised it lasted so long.
With plain filaments the standard nozzle is good for 9 - 12 months but all abrasive filaments require toughened nozzles - hardened steel, ceramic or even ruby.
https://help.prusa3d.com/article/composite-materials-filled-with-carbon-kevlar-or-glass_167387
Veröffentlicht : 26/01/2023 2:03 am
Victory Sports
(@victory-sports)
RE: PA12 CF Nylon Nozzle Clogs
Sorry forgot to clarify that. Using ED3 hardened steel.
Veröffentlicht : 26/01/2023 2:04 am
Victory Sports
(@victory-sports)
Is clogging a symptom of wearing out a nozzle? Maybe I got knock offs?
Veröffentlicht : 26/01/2023 2:05 am
With inclusions it's often a symptom of a too narrow nozzle - what diameter does the filament manufacturer suggest?
Eg, almost all woodfill filaments suggest a min of 0.6mm. CF differs by manufacturer.
Veröffentlicht : 26/01/2023 2:28 am
Victory Sports
(@victory-sports)
It's Polymaker PA12-CF. They Don't seem to recommend a specific nozzle size but it makes sense with the carbon particles to use a bigger size. However the original question remains. Is there a way to unclog it? I don't mind doing that every 12 hours of printing.
Veröffentlicht : 26/01/2023 3:01 am
You should be able to burn it out but you might have to retemper the nozzle afterwards.
Veröffentlicht : 26/01/2023 9:25 am
Hold the nozzle over a heatgun to warm it up and see if you can use the fine needle to push the filament out.
Veröffentlicht : 26/01/2023 11:44 am
