Orca slicer- can I use MK3S configuration for my MK3?
Hi, I have the standard MK3 and I want to try out the Orca slicer with it. It doesn't have a selection for the standard MK3 but it has one for the MK3S. Can I use that to slice for my MK3?
RE: Orca slicer- can I use MK3S configuration for my MK3?
probably. The MK3 will pause at start saying: "This was made for other printer, do you want to continu?"
Sounds good, I'll give it a try. What's the worst that can happen? Thanks a lot.
You are triggering my imagination:
The worst I can think off:
- You will get on the first page of the local newspaper because, there was an explosion in your home. And parts of it landed on the local town hall.
- A little Frankenstein is printed on the sheet and it says "hello" when you check it.
- The printer stops printing and never starts again.
- mmmmm
More realistic:
- the print is not run and stops with an error.
- it is misplaced on the plate a bit.
- maybe some printing errors
- the g-code also holds the settings for filament, temps, that might give differences, to the profile you are used to.
That is about it. I have a MK2.5S and run MK3(S(+)) code on it. Besides the message never seen a problem
Thanks much. Really it would be pretty cool if I printed a talking Frankenstein, huh? I'll try it on a couple of my usual settings and see if anything weird happens.
