One of three parts warping
Poesghost
(@poesghost)
Hi again everyone! I'm having another odd issue. Part of the print is warping and it doesn't seem to start until near the end. I am using Prusament Vanilla White PLA. Nozzle temperature is 215 and bed temperature is 60. Any ideas as to what could be causing it for only one part in the area it's happening?
Opublikowany : 05/11/2022 9:49 pm
RE: One of three parts warping
Same advice as for all the other warping posts:
* Clean the sheet with hot water and soap
* Make sure your live z is optimal. From the photo looks like there's some waves, which indicate nozzle too low. But always hard to gauge from photos.
* if needed, consider a brim or Mickey Mouse ears in the area of the warp.
* if needed, try Layerneer, Magigoo or another adhesion agent. A little bit will go a long way.
Opublikowany : 06/11/2022 7:28 pm
Poesghost
(@poesghost)
Thanks for the reply. I do clean the sheet with soap and water. I will adjust the Z, raising it a little more. I haven't tried adding a brim yet. It was just an odd place for it to start warping and not until the last few layers did it start. The roll was new too so it wasn't like I was using old filament.
I'll make the change and report back and mark this as resolved if that fixed it.
Posted by: @fuchsr
Opublikowany : 06/11/2022 7:58 pm
Razor
(@razor)
Don’t forget, new filament can be wet and/or have issues.  I’ve had wet new filament before.
Mini+MK3S+XL 5 Tool
Opublikowany : 07/11/2022 2:54 am
