Odd size for hex socket head screw holding in heater cartridge
[Résolu] Odd size for hex socket head screw holding in heater cartridge
Dik Harrison
(@dik-harrison)
On my MK3 E3d hot end, 1.5mm too small, 2mm to large. Has anybody seen this and what is the solution? I have to replace my cartridge...
Publié : 10/05/2019 3:46 pm
vintagepc
(@vintagepc)
Membre
RE: Odd size for hex socket head screw holding in heater cartridge
One of the hex keys you got with your Mk3 should be correct. I think it is 1.7 or 1.9.
Publié : 10/05/2019 3:55 pm
Dik Harrison
(@dik-harrison)
The E3D site says it should be 1.5mm.  I have all that came with the printer plus several sets of my own, nothing fits...
Publié : 10/05/2019 4:03 pm
vintagepc
(@vintagepc)
Membre
... is there some melted plastic stuck in it? Might need to find a way to get that out then... (heat gun/dental pick?)
If your hotend doesn't have a silicone sock, strings that get blown back are directly inline with that screw head and murphy dictates they will catch and melt onto it...
Publié : 10/05/2019 4:10 pm
Dik Harrison
(@dik-harrison)
I'll double check, but as IK mostly print black, black on black is hard to see.  I do use a sock, but the block is very "dirty".  Even so, that would make the size 2mm, not 1.5mm as E3D says.
Publié : 10/05/2019 5:06 pm
vintagepc
(@vintagepc)
Membre
It could feel that way if the wrench isn't seating deep enough to engage well. The only other thing I can think of is the screw might be stripped. Have a look with a mirror and a bright light?
Publié : 10/05/2019 5:12 pm
Dik Harrison
(@dik-harrison)
Finally, totally uninstalled, there was some plastic in the socket.  Got it undone with a 2mm hex key provided by Prusa.  Have a new cartridge on order.  Thanks for the help.  Guess I'm too old to troubleshoot things anymore.
Publié : 10/05/2019 6:19 pm
vintagepc
(@vintagepc)
Membre
Everyone has "derp" moments sometimes.... 🙂
Glad you got it sorted.
Publié : 10/05/2019 6:31 pm
