[Rozwiązany] Octoprint on Pi4 2gb, can't reset the password.
Ofer Krupka
(@ofer-krupka)
Software: Octoprint 0.18.0. (the stable 0.17.0 doesn't work on my pi 4)
Raspberry Pi 4 Model B 2gb.
I changed the password from "raspberry" according to PRUSA.
And then when I tried to log in with the RIGHT password, it says "Access denied".
I followed this guide to reset it (Googled: How to reset raspberry pi password).
Then this guide (Googled: octoprint reset ssh password).
I even tried to format & reinstall the Octopi image, I guess the password isn't stored there because it didn't work either.
Just can't reset it 🙁
Thanks for the help in advance!
Best Answer by bobstro:
Try "pi"(lowercase) for the username.
Opublikowany : 24/12/2020 11:54 pm
RE: Octoprint on Pi4 2gb, can't reset the password.
This might help:
http://mapledyne.com/ideas/2015/8/4/reset-lost-admin-password-for-raspberry-pi
Opublikowany : 25/12/2020 2:14 am
Ofer Krupka
(@ofer-krupka)
@cwbullet
You didn't read my post... :/
Opublikowany : 25/12/2020 11:03 am
Pedroid
(@pedroid)
This sounds suspicious. Maybe you connect to a different device?
Opublikowany : 25/12/2020 11:05 am
Ofer Krupka
(@ofer-krupka)
@pedroid
I only have one rpi in my house, on top of that I look at the ip address written on the Pi's screen.
Opublikowany : 25/12/2020 11:11 am
@ofer-krupka
Yes. I read your post.  You don't have to a jerk.  It does not encourage help.
I guess you're out of luck.
Opublikowany : 25/12/2020 1:53 pm
Ofer Krupka
(@ofer-krupka)
@cwbullet
oh, sorry that it sounded this way, didn't tried to be mean.
Opublikowany : 25/12/2020 2:46 pm
Explain how you're trying to log in. Are you on the RPi console trying to log in with the pi user, connecting via ssh, or trying to log in with the Octoprint web interface?
Opublikowany : 25/12/2020 3:09 pm
Ofer Krupka
(@ofer-krupka)
Connecting via ssh with PuTTY.
In Pi (console), I think it says "Login incorrect" (from some reason the text too small & barely readable, 5inch 480x800 screen).
Octoprint web interface is totally fine (for now, I have another problem I have to solve there in this post).
Opublikowany : 25/12/2020 3:15 pm
I assume you enabled ssh access, correct? Are you specifying the pi username when connecting via ssh?
OctoPi should have ssh enabled, buy if you installed OctoPrint yourself, it's a good idea to confirm.
Opublikowany : 25/12/2020 4:23 pm
Ofer Krupka
(@ofer-krupka)
Opublikowany : 25/12/2020 4:25 pm
Opublikowany : 25/12/2020 8:48 pm
2 ludzie polubili
dimprov
(@dimprov)
Posted by: @ofer-krupka
But that has to work.  Is your caps-lock on?
Opublikowany : 25/12/2020 9:56 pm
Ofer Krupka
(@ofer-krupka)
@bobstro
WHAT, am I that stupid?
Oof.
Anyway, thanks everyone who helped me!
Opublikowany : 26/12/2020 3:05 pm
@ofer-krupka
I think we have all had a "Duh" moment with 3D printers and Raspberry PIs.  It is frustrating and hard to communicate the problems.
Opublikowany : 26/12/2020 3:27 pm
