Nozzle Temperature drops to 0°
dominik.a3
(@dominik-a3)
i have a MK3 which is about 2 months old now.
Since about 2 weeks i have a problem... when i print bigger prints (different one) after a few hours the noozle temperature drop to 0° and the fillament get stuckt in the extruder. The printbed stays on 60°. I checked also the casbles from the extruder but they are ok.
I have also a new second printer where i can print without problems. Both printer run same firmware 3.4.1.
Can this be a problem of the EINSY RAMBo motherboard?
Thanks in advance!
Publié : 11/01/2019 10:03 pm
thrawn86
(@thrawn86)
Re: Nozzle Temperature drops to 0°
the cable is failing somewhere you can't see and that's why its intermittent. If the connectors and board look okay, I'd replace the thermistor cartridge before trying anything else.
Publié : 12/01/2019 3:03 am
toaf
 toaf
(@toaf)
my vote is almost the cable.
Publié : 12/01/2019 3:13 am
stahlfabrik
(@stahlfabrik)
Is the measured temperature dropping to 0 or the target temperature?
Publié : 14/01/2019 9:42 am
