Nozzle replacement issue
Hi all, I went to replace my nozzles with new brass nozzles for printing/steel nozzle for high speed printing and when i went to remove the nozzle, it was screwed in so tight i physically couldn't move it. I had heated up the nozzle to around 220C and turned the heat block slightly (as recommended in a few tutorial videos i watched). I haven't previously changed the nozzle and i have not tightened it either, so i was hoping someone may have a suggestion for loosening the nozzle (there is pretty much no gap between the nozzle and the heat block).
TIA
RE: Nozzle replacement issue
TIA
Hello, welcome to the Prusaforum.
You can try to heat the nozzle to 280 degrees C. To remove you need a 16 mm wrench and 7 mm socket wrench. With the 16 mm wrench you fix the heating block. If there is no other way, you have to remove the hotend. A gap between the bloch and the nozzle is very important:
