Nozzle get loose after Print PC Blend at 275°C
Hello,
after I print PC Blend the first Time I get a massive Blob at the Nozzle with the next PETG print.
The material comes out at the Nozzle and at the Heatbreak
OK, clean it, check the Nozzle, it was loose.
Screwed tight in order to the E3D Manual at 285°C.
Print some PETG all fine.
After the next PC Blend print, I checked the Nozzle, it was loose again.
Did anyone know that Problem or have a Solution?
May the temperatur difference between fixing at 285°C and printing with 275°C is to little.
Greetings from Berlin, Uwe
Uwe Prusa i3 MK3S Kit, MMU2s
... Ãber 90% aller Fehler sitzen vor dem Bildschirm, fragt sich nur vor welchem. 🙂
... Over 90% of all errors are in front of the screen, the only question…
Publié : 24/07/2020 7:46 pm
