Nozzle dragging in ABS
Is there a way to set filament height using ABS when only first print configuration is only for PLA?
I’m having a problem printing ABS after the first few millimeters as the nozzle seems to be dragging into the perimeter.
I just finished the MK3 kit, the PLA is printing good.
Veröffentlicht : 24/08/2018 4:14 am
Re: Nozzle dragging in ABS
when it heats up, go to Tune and lift your Temp. no big deal. you have to lift your temp 2 times. once at the beginning and again after your bed reaches temp.
Veröffentlicht : 28/08/2018 12:18 pm
