Nozzle clogged after firmware update?
zenocon
(@zenocon)
This is the first clog I've had.  I was a few firmware revisions behind, and yesterday upgraded to the following: prusa3d_fw_MK3S_MK3S+_3_11_0_4955.hex
After doing many of the same multi color prints before the firmware upgrade, after the firmware upgrade when I went to change the filament on a color change I got a jam.
Here's a video illustrating the jam condition
I tried to then research clog/jam resolution.  I followed the main manual section 13.4 but it did not resolve the issue.
I followed the guidance of this YT video, but it did not resolve the issue.
I released the screw and opened the hatch, and used a sharp dental tool to scrape filament out of the gears.  I cycled the auto-filament process until I had scraped out all the filament entrails from the extruder gears.  I used the dental tool to try to push the clog down the filament hole to no avail.  I pushed it down somewhat, but the length is limited.  I tried to use a piece of PLA filament (I only have PLA), to push it down after heating up the nozzle to PLA temp of around 180. I was able to push it down a bit but then no more.  Then, I tried auto-loading a piece of PLA filament after replacing the screw.  It took, but if I try to do a print, the machine acts like it is printing but nothing comes out of the nozzle.
Next I tried taking a very sharp pointed dental tool and poked it up the nozzle to see if that would relieve it; it did not.
I'm looking for tips / guidance on how to get the printer un-clogged...?
Thanks in advance!
Davis
Opublikowany : 08/06/2022 2:32 am
Start with a cold pull:  https://help.prusa3d.com/article/cold-pull-mk3s-mk2-5s_2075
Opublikowany : 08/06/2022 8:58 am
