Nozzle brokes into the extruder
Cycleman
(@cycleman)
hey guys
I push too much torque to my nozzle and now is broken into the heatsink. the half is inside.
Is finished or there is a way to put it out?!
if I can't do anything....what I need for that?! only a heatsink and a nozzle?!
thanx.
thanx.
Ce sujet a été modifié il y a 5 years par Cycleman
Publié : 11/07/2021 8:45 pm
Membre
RE: Nozzle brokes into the extruder
I would recommend you just buy another.  You could heat it up with a heat gun and try to remove it.
Publié : 12/07/2021 1:10 am
Cycleman
(@cycleman)
so what I need?
a heatblocker, a nozzle and a thermal paste?!
thermal paste I have some that I use for pc cpu. Is ok? or I must take this one ?
thanx
Publié : 12/07/2021 7:14 am
Membre
Nozzle, heatbreak, heat block, and thermal paste.  You might need a thermistor and heat cartridge if you can't get them loose.
Publié : 12/07/2021 11:08 am
1 personnes ont aimé
Cycleman
(@cycleman)
well I heat it up and finally goes out.
Just fine.
so I order only heatblocker and paste.
as I see the manual for assembling says 0.5mm. I buy some gap fillers for that. Also they don't say that I must heat up again and tighten up just little as I see in YouTube. In that video a guy heat it up after he tighten just a little and he left it to cool. he did that 3 times.
is that necessary ?!
Publié : 13/07/2021 2:10 pm
Posted by: @cycleman
hey guys
thanx.
thanx.
To prevent such problems, you could use a torque tool. There are also some to print yourself, like this one:
https://www.thingiverse.com/thing:2613057/comments
https://www.thingiverse.com/thing:4332963
https://www.thingiverse.com/thing:4738816
wbr,
Karl
Publié : 13/07/2021 4:49 pm
