Nozzle brokes into the extruder
hey guys
I push too much torque to my nozzle and now is broken into the heatsink. the half is inside.
Is finished or there is a way to put it out?!
if I can't do anything....what I need for that?! only a heatsink and a nozzle?!
thanx.
thanx.
RE: Nozzle brokes into the extruder
I would recommend you just buy another. You could heat it up with a heat gun and try to remove it.
so what I need?
a heatblocker, a nozzle and a thermal paste?!
thermal paste I have some that I use for pc cpu. Is ok? or I must take this one ?
thanx
Nozzle, heatbreak, heat block, and thermal paste. You might need a thermistor and heat cartridge if you can't get them loose.
well I heat it up and finally goes out.
Just fine.
so I order only heatblocker and paste.
as I see the manual for assembling says 0.5mm. I buy some gap fillers for that. Also they don't say that I must heat up again and tighten up just little as I see in YouTube. In that video a guy heat it up after he tighten just a little and he left it to cool. he did that 3 times.
is that necessary ?!
hey guys
thanx.
thanx.
To prevent such problems, you could use a torque tool. There are also some to print yourself, like this one:
https://www.thingiverse.com/thing:2613057/comments
https://www.thingiverse.com/thing:4332963
https://www.thingiverse.com/thing:4738816
wbr,
Karl
