Nozzle, and hotend not heating up
My printer heats up, but never reaches working temperature. Even though the printer's display shows the temperature as correct. Here I've placed a thermistor on the heat block and reading 117.C. When I point an infrared thermometer at the nozzle, I get no more than 35.C. This has happened to me before (6 months ago) and I replaced the hotend. I was just checking if there are any more options I can follow before buying yet another hotend
0"]
printer display shows 230.C, but actual temperature is 117.C[/caption]
RE: Nozzle, and hotend not heating up
Your thermistor need replacing don't even attempt to heat up the printer before you replace it as the printer can heat up to crazy temp
