Not printing after initial mesh bed leveling
Admittance
(@admittance)
Hi I've had my printer a while it was working perfectly, I stopped using it for a couple months around late October at that time it was working fine i come back to use it today to print something all seemed well bed/hotend heats up fine the printer runs the starting bed mesh level calibration and then stops at the point where it would normally do the initial purge line before moving on to start the print the screen shows the temps to be normal but the remaining time and percentage runs down very fast. I checked the extruder all clean and pushes out plastic as you would expect it to, i then ran the setup wizard to make check if there was anything wrong there all fine until it comes to the test print for live z leveling and as soon as it would normally start it stops and i am presented with the finishing message asking if would like to restart the live z level test as if it had just done the print as normal.
Napsal : 16/01/2020 6:25 pm
