Not enough filament coming from the nozzle
James AZ
(@james-az)
After about 30 prints, my new i3-Mk3s is not printing.  I have done all of the calibration tests, adjusted Live-Z and still not enough filament coming from the nozzle.  A temperature check for PLA 215/60 showed 98/58.  I removed the nozzle and it appears that the filament is backing up and not coming out of the nozzle.  I am wondering if the temperature sensor on the nozzle is not working.
Any ideas....
Napsal : 03/07/2020 12:47 pm
jsw
 jsw
(@jsw)
RE: Not enough filament coming from the nozzle
Well, at 98C, the filament will most definitely not flow properly out of the nozzle.
I would suspect the heater element or the heater wiring before the thermistor.
Napsal : 03/07/2020 3:11 pm
1 lidem se líbí
Posted by: @jmmgroup
Any ideas....
98 degrees C. is way too low. I'd check the heating element and the thermistor. Maybe you got a loose connection or an element malfunctioning. I would always keep these parts on stock.
Napsal : 03/07/2020 3:21 pm
