Noisy y-axis, setting to reduce speed?
Hi everyone, my Y-axis is loud when it is moving during extrusion. When it is moving to reposition the extruder (not extruding), it is generally okay. I think it is partly due to vibration. Everything is tightened down.
When I slow the global print speed to 87% it is really quiet. To make this setting from PrusaSlicer, so I change the `Maximum feedrate Y` in Machine limits? I think I would change the X feedrate, too. I see there are also a setting for `Maximum acceleration when extruding`, but I am not sure if that is a relevant setting. I don't really care much for hardware troubleshooting or replacing stuff (I see there is a Y-axis mount upgrade on Printables), and am fine with adjusting the print settings.
Thanks all.
Postato : 03/03/2024 1:25 am
