Noisy / resonating x-axis
Neil
 Neil
(@neil-2)
MK3S+
I've read a few posts about noisy and resonating printers. There seems to be a vast array of possible causes - almost as many diagnostic processes people have attempted. I'm here to ask a couple of basic questions about my specific issue and I'll keep the thread up to date with what I do and how (hopefully) I eventually solve it to help others in the same situation.
Printer is a self-build and had no immediate issues at all. In fact, I was somewhat surprised with how well it just worked (I assume my patience in the build made the difference). After a few months I noticed a noisy rattle sound, like a screw was loose and being vibrated by the mechanical vibration of one of the axis or motors.
It took me a while but I managed to find that by squeezing the x-axis tensioner assembly with my fingers (see below), the noise stopped.
I also noticed that it was worse in normal mode, but only a little better in quiet mode.
I realise that resonance issues are complex and by pushing on the assembly I dampen it and could be stopping whatever is resonating from doing so. However, it does seem like the sound is coming from the bearings.
So, my questions:
  1. Would you go straight in and assume it's the bearings and attempt to repack with a good grease? If so, does anyone have any guide for the least trouble in dismantling ?
  2. Are there anything other diagnostic steps anyone would suggest I try before tackling the disassembly?
Thanks!
This topic was modified 4 years ago 3 times by Neil
Posted : 09/06/2022 1:04 pm
Cadme1ster
(@cadme1ster)
Yes, after a few months it can use some fresh lube on the inside of the bearings.
This is a good manual: https://help.prusa3d.com/guide/how-to-replace-bearings-on-the-x-axis-mk3s_214556
You can stop once the Z Axis comes off or just lube the X Axis bearings as well once you are at it.
This post was modified 4 years ago by Cadme1ster
Posted : 09/06/2022 1:54 pm
Neil
 Neil
(@neil-2)
RE: Noisy / resonating x-axis
Thanks @mpothmann - not sure how I missed that maintenance page. I don't suppose there's any other way to do it than just to do it...
I think I'll print off the superlube slotted nozzle and do a good job with all the bearings while I'm at it. Not looking forward to the disassembly, but here goes...
Posted : 09/06/2022 2:20 pm
