Noise on the X axis
sascha-1
(@sascha-1)
Noise on the X axis
Hi there,
recently had the problem that my Prusa i3MK3S makes a noise on the X axis! It is a whistling or squeaking.
Does anyone have any idea what that might be?
Many thanks and greetings
Sascha
Napsal : 01/01/2020 10:28 pm
rmm200
(@rmm200)
RE: Noise on the X axis
Check your X axis bearings - and the idler.
Power off and move the extruder both directions. Do you feel any binding?
For a temporary fix, you might try a light oil on the rod. This is not a replacement for packing the bearings with grease.
Also, the bearing mounts on the extruder might be too tight. Try loosening them a bit.
Napsal : 01/01/2020 11:30 pm
Posted by: @sascha-1
Hi there,
Sascha
In such cases, a video could be very helpful. I bet on the bearings..
Napsal : 02/01/2020 3:10 pm
Mine was the bearings!
Napsal : 03/01/2020 4:51 am
