No Ultradetail or Detail presets selectable when using MMU2.0
sensor_todd
(@sensor_todd)
I've got a MK3 with MMU2.0 and I've just noticed if I select the Original Prusa i3 MK3 MMU2 from the Printer Settings tab in Slic3rPE (1.41.3+win64) and go to the Print Settings tab, the smallest layer height I can select from the System Presets is 0.15mm Quality MK3.
Is there a reason there is not the option to select 0.05mm Ultradetail/0.07mm Ultradetail/0.1mm Ultradetail when using MMU2?
If I select Original Prusa i3 Mk3 MMU2 Single from the Printer Settings tab, these Ultra/detail options are available in the Print Settings tab, but I would like to do a detailed print with two materials. Am I likely to run into print issues if I copy these options across to the User Presets for the Original Prusa i3 Mk3 MMU2?
Thanks
Todd
Veröffentlicht : 10/04/2019 12:34 am
toaf
 toaf
(@toaf)
Re: No Ultradetail or Detail presets selectable when using MMU2.0
you can change setting to make your own setup. it works, some crazy setup to get it perfect
Veröffentlicht : 10/04/2019 12:45 am
sensor_todd
(@sensor_todd)
Thanks, I've copied the 0.05mm settings over to a user preset for the MMU2 configuration, I'll try a print tonight and see how it comes out.
Thanks
Todd
Veröffentlicht : 11/04/2019 1:05 pm
