No print restart after power out
Rubi
 Rubi
(@rubi)
Hi
After updating to the latest official firmware, my printer does not restart after power out.
I assume this is related to the preheat error I had where it stopped printing at the beginning of layer two, when the fan started at full speed.
I could fix this error by running pid and temp calibration, after that the preheat error was thankfully gone.
Problem description:
When I turn of the printer and restart it heatsw up, positions itself but then the fan starts, the temp drops noticable and it takes a wghile until end temp is reached but the printer refuses to start printing, altough the bed and nozzle temp are reached.
Please advice.
Cheers
Michael
Veröffentlicht : 11/02/2019 2:23 pm
Rubi
 Rubi
(@rubi)
Re: No print restart after power out
Hi
Am I the only one with this problem ? Very strange.
Cheers
Rubi
Veröffentlicht : 08/03/2019 12:31 pm
vintagepc
(@vintagepc)
Mitglied
are you using the power switch to turn off the printer? Rumor has it that doesn't actually trip the power panic sensing reliably; you'd need to actually pull the plug from the wall or something.
Veröffentlicht : 08/03/2019 1:22 pm
Rubi
 Rubi
(@rubi)
Hi
Thank you ! , I just used the switch, will try that today.
Sometimes my octoprint disconnects and if I want to supervise the print cutting power would be an option.
It is not optimal tough because I lose remote controll functionality but at least I would have a video feed.
Cheers
Rubi
Veröffentlicht : 08/03/2019 2:32 pm
The power panic is a great idea, but there are things that will make it not work right. Many related to the filament sensor issues (Mk3 style). I would not depend on it for normal workflow. PAUSE is a better way to manage flow.
Veröffentlicht : 08/03/2019 8:14 pm
