No filament during print but not blocked
fMD
 fMD
(@fmd)
Membre
Hi all,
I have an MK3S that has been printing fine until recently.
I can swap the filament and nozzles and it heats fine and filament extrudes well during the swap. But when I got to print nothing comes out. It asks me to unload and reload the filament at the beginning of the print and I do, and filament comes out again, but it still doesn't print. Using PLA at 210-220c.
Any ideas? Thanks!
Publié : 09/02/2026 4:49 pm
fMD
 fMD
(@fmd)
Membre
RE: No filament during print but not blocked
Posted by: @fmd
Hi all,
Any ideas? Thanks!
I disabled the fil sensor and it's working now. But the sensor showed 1 so it was detecting filament. Is the next step to clean the sensor? Thanks!
Publié : 09/02/2026 9:30 pm
Yes. Fine stringing or dust can jam the moving part causing false reporting.  First try a blast of compressed air...
Publié : 10/02/2026 5:40 am
fMD
 fMD
(@fmd)
Membre
Thanks! I did this but it stopped working again even with the sensor turned off. What's my next step? Thanks again
Publié : 10/02/2026 2:40 pm
Check the sensor is reporting correctly (LCD menu) as the next step is disassembly, checking for  'sticky' dust/debris and worn parts.
[This is where a spider attaching one end of a web to the filament can cause disproportionate problems - the web is pulled into the sensor and, being sticky, glues the wrong things together.]
But first do a cold pull in case of a partial blockage - unlikely but easy to do without resorting to the screwdriver...
And, incidental, the filament change at the start suggests you might be using a multi-extruder preset with a single extruder printer..?
Publié : 11/02/2026 8:29 am
fMD
 fMD
(@fmd)
Membre
Thanks. Could it still be the sensor even though I disabled it?
Good catch. I have a mmu attached but never got it to change filaments correctly, so I gave up on it. This error asked me to reload filament though.
Publié : 11/02/2026 12:58 pm
That's why I suggested the cold pull - but we already know this is a compound problem with issues interacting - check the sensor is reporting correctly with and without filament a few times...
And you may find the reload problem goes away with the correct preset.
Publié : 11/02/2026 8:54 pm
CodeCage
(@codecage)
I seem to be having the same issue. Filament loads perfectly but then no filament when printing begins.  Somewhat of a newbie, so where do i find this multi-extruder preset with a single extruder printer.  It is a MK3S+.  And no experience with MMUs.  Is a cold pulled only associated with an MMU?  Not familiar with the term.
Thanks in advance for any help!
Publié : 13/03/2026 2:41 am
